kevinc1980
I have a 2014 Bad Boy MZ Magnum 54" and the right Deck Pivot Lever has broke. It appears the only way to remove it to replace it is grind off the weld where it is welded to the shaft that goes through the frame rail. Both the left and right are welded to that shaft. Am I correct that this weld needs to be ground off in order to replace that broken piece? Just trying to verify before I break it further while fixing it, otherwise it still is a great mower. For reference it is part # 031-1020-00 item # 15 on the diagram on page 29 of the owners/parts manual.
