What does measuring resistance of a plug tell you, some resistance, open or solid? A little carbon cani distort the readings and some plugs use a small gap internally to act as resistance. When you are charging a customer by the hour why do it? Replace and recycle, go for it, but I still say testing it is a waste of time, unless you’re that curious.
