Squirrel Master
So I adjusted the vales. The exhaust was actually within spec but the intake was a bit loose. I was surprised at how much the rockers wiggle around when not depressing the valve. I originally thought it was the exhaust valve but after actually checking tolerances I was wrong. The Intake was allowing up to .007. That doesnt seem too out of wack so I dont know if its going to suddenly make the engine run perfect. As far as the coil, I pulled the spark plug and reattached the boot, placed it against the engine and cranked it over. It seems to spark just fine. HOWEVER, the boot had a good size tear in it and I was being shocked while holding the boot. Obviously not good and maybe we found our issue... That being said, I've electrical taped the boot just to test it. I was thinking the charge was jumping to another part of the engine since the wire is routed so close to everything. Now once the silicon on the valve cover cures this evening I'll try to start it again and we will see if the problem is fixed. Fingers crossed but I'm guessing the valve being slightly out of tolerance and the spark plug boot crack isnt the main problem... Hopefully I'm wrong...
