Lift
Ariena
I'm looking for a lift of some sort to get my tractors off the ground. I have seen the Mojack and truthfully was not overly enthused with it.
Does anyone have other recommendations?
Thanks.
Re: Turf Buddy
If you don't like the Mo-Jack try looking at the Turf Buddy. I personally use the Mo-Jack EZ for both my ZTR mowers ans my walk behind and it works great.
turf buddy
I worked at a place that had two old forklifts, the hydraulics were converted to run on the shop's electrical power. Additional channel was welded on to the forks to accomodate the wheelbase of the mowers.
I think I'll fab up something using a 10,000 lb. truck winch I've got and some square tubing. I also saw some things out there that didn't fit my needs (or budget) on the web.
Re: Turf Buddy
Turf Buddy is also a good choice. Though, like Ric I also like the Mo-Jack, as that is what I'm using frequently.
