03grandam
Hello all first time on this forum I’m lookin for some help with my mower, I have a John Deere D105 I believe it has a 17hp engine on it. It will start off of starter fluid being sprayed into the carb. But it’ll just spin over with out it. I have checked the fuel solenoid it is working, I’ve changed the spark plug and made sure I’m getting spark which I am, I’ve changed the fuel filter, I’ve cleaned out the carb and made sure it was getting fuel into it, made sure there was nothing in the fuel lines it also has fresh gas in it so I’m not sure why it wont start I’ve tried checking everything I’ve known to check there doesn’t seem to be an electrical issue I could be wrong but I don’t believe there is if anyone has any ideas anything would be appreciated thank you.
