fdsinozich
Runs fine otherwise.
New blade does not mean sharp blade. Also. any grass build up under the deck? If yes this will really slow the mower down. Also, are you bagging the clippings? Cut lawn at 3" ....what do you have the wheels set at ? Lots of things can cause bogging including wet grass. Best of luck!Cut the lawn last week at 3", again this week at 3". Runs at 3100 rpm and bogs under minimal resistance. The blade is new, air vane moves freely. I've had the mower six years. I'm at a loss what to try next.
