- Nov 29, 2014
- 24,995
It's a bug bear of mine
Got 2 Great Danes in the run with 18Hp Commands
One has the filter mounted on a stand alone bracket so it is just 2 extra bolts.
The other has 3 brackets holding it to the blower housing so it is 12 nuts & bolts to remove the filter + 4 more on the housing before you can even think about taking it off.
So there is after all canister filters go on the ROPS if possible & fitted vertically .
FWIW the Engineaire brand filters are a lot cheaper than the Donaldson ones
