brinkkl2000
am working on an old 112 that will just grind the gear when trying to shift in from neutral. I have pulled off the belts, did not replace as they look fine, and made sure the variator was moving freely and put some lube on the center shaft to make sure it continues to slide. I have adjusted the clutch pedal/ variator per the manual. I have verified that the variator is working as it should while the engine is running, the belts are moving up and down the sheave respectively. When I start the engine and the clutch is depressed I can shift in to any gear, however, once I have done that and I push in the clutch, it will not fully release. The engine to var. belt will continue to spin and I can now not put it in to any gear. I can shut down the engine and do the process over again and it will work fine. I can only shift in to a gear from the first start of the engine. I cant quite tell if the adjustment is moving when pressing down on the clutch, but I have that bolt as tight as I can and the clutch is returning all the way up. What else could be my problem?
