- Sep 5, 2012
- 976
So, we now know where the new EGO 56 volt 10 Ah batteries will be used, since they are too large to fit in the current walk-behind mowers. It will be interesting to see how much this will cost, since the current offerings from Greenworks and others are priced in the stratosphere. Assuming each 10 Ah battery weighs 9 lbs, with 4 batteries it would weigh about 444 lbs, which is about 170 lbs less than the Ryobi 75 Ah 42" ZTR with SLA batteries.
egopowerplus.com
Available Now! The Z6 Zero Turn Riding Mower | EGO
Prepare to conquer tight turns, cut as many acres as needed, and completely customize your mowing experience. Buy your Z6 now!
