Grumpy boy
Briggs and Stratton Magnetronic 3.5hp engine for lawnmower. Serial number indicates built in 1992. Unused for a number of years - was running OK before being put into storage. Generally cleaned up; sump and petrol tank cleaned out; air and fuel filters cleaned; carburettor dismantled and cleaned out - diaphragm appears in serviceable condition; jet clear; Choke-a-Matic flap free and fully closed when not running.
Engine will not start cold. If I take the air filter off and put my hand over the air inlet (ie. really choke it) and pull the start it will start after a couple of pulls then I take my hand off. Chole-a-Matic flap fully open. If it doesn't keep running it will restart with another pull. Engine runs very well. If stopped the engine can be restarted easily -- until it is cold again.
Any ideas?
Any ideas?
