upupandaway
- Jul 3, 2015
- Threads
- 33
- 590
I have a "chopsaw" "cut-off saw" K770 where the compression is too low - 60psi. Spark OK, spray starter straight into dry cyl no go. Looking from carb side, the piston looks perfectly fine if not better than some pistons that work.
My first assumption is it needs a new cylinder\piston but as clean as it looks, can bad rings alone result in this low psi or indeed is it always bad cylinder?
