Preston1977
You
You were spot on dude, very much appreciate the help! Now I just have to figure out the pulley and belt lay out.Hope you survived the storm.
The grey should go battery voltage with the ignition turned on
If so it goes the solenoid on the carburettor .
The black should be open circuit to ground with the ignition turned on & ground when the ignition is turned off and if that is the case it goes to the magneto .
The red will be battery voltage and goes to the rectifier
