Hills and mowers
Bethieboo
At the front of our property is a steep hill that can be very difficult to mow. Some days I just use the gas trimmer to cut it. What are other ways to trim the grass on steep hills?
KennyV
Depends on how steep it is... BKBrown has a VENTRAC mower that will work on very steep ground...:thumbsup: there are some (expensive) hill side mowers built to do that type work... How big an area and how steep I guess is the question. :smile:KennyV
Ric
The first thing I would ask is how much property are we talking about? My guess is you are talking about using a gas trimmer so apparently were not talking about that much property, so I wouldn't go out and spend a lot of money on specialty mowers. The next thing I would ask is how are you attempting to mow the steep hill with your mower, are you mowing perpendicular or not because it will make a big difference with how your Honda will function. If you have more property than the Honda will handle you mite consider stepping up to a good Gear Driven Walk-Behind Mower and you can purchase them with a 32" to 61" mower deck. I mow a dozen or so property's with steep slopes and that's what I use and it works very well and they have an excellent cut.
Usedtorent
Why not push mow it? That is what I would do. I don't trust myself or my mower on steep hills. I prefer to push them. It's a tough job but at least I feel safe. :biggrin:
JDgreen
Maybe one of those robotic mowers? But they will not cut worth a darn when the grass is too high. Another solution...kill all the grass and replant with ground cover.
jacko
Last week a guy who lives near me lost 2 toes while mowing a hill with his push behind when it was slick. He shouldn't have mowed a hill with slick glass but I guess he learned the hard way.
BKBrown
Thanks Kenny!
The Ventrac is good for steep grades AND will take quite a few attachments.
Ventrac Compact Tractors & Attachments also an American Company Ventracs are made in USA
Bethieboo
It is not a large area and I do it with a push mower. I wish I knew how to measure the grade but I know it is a lot. The problem is that it is a very visible part. I was thinking about ripping all the grass out and putting in ivy.
KennyV
You could always plant something like Sedum... very hardy most types only grow to 4 inches high, lots of color to choose from.... never needs mowed.
Sedum Photos
:smile:KennyV
outdoors Joe
Sedum would look good and if you like, you could plant other flowers with it. Not only would you have a beautiful hillside, but you wouldn't have to take a chance on getting hurt mowing it.
