- Sep 24, 2017
- Threads
- 288
- 6,885
are you sure enough air is getting to the carb for a proper mix?
It should be getting plenty of air as I tried starting with the air filter removed.are you sure enough air is getting to the carb for a proper mix?
I have this older generator with the HM100 10HP engine that I am having issues with it starting/running. This is a used generator (1999) with very few hours I received for free because of the plastic fuel tank split issue on these Devilbiss 5250 generators. So i replaced tank and tried starting and it initially started well but the engine surged or hunted so I assumed it was carburetor since this unit sat for a few years with old gas. So I let it sit for a few more years and now i took carburetor off and cleaned out fairly well but didn't solve problem in fact now it is harder to start. So I ordered one of the aftermarket carbs on Amazon for $12 figuring what could I loose. That carb didn't work either so now it only would start quickly on choke but would either surge or stall out and not remain running. The carb wasn't exactly like the old so I thought let me rebuild the old carb with an OE Tecumseh kit. So got the kit and changed out emulsion tube seals, float valve seat and needle, bowl gasket and jet gasket. Float was plastic one with no leaks so I was able to re-use. Cleans all the main jet orifices and passages, made sure carb cleaner would spray through all passages under welch plugs but didn't remove them. When I tried to start with the old rebuilt carb it acted the exact same as the new aftermarket carb, would start on choke but would stall after a couple seconds. The only thing I haven't changed is the carb to manifold gasket although it looked good. Could I be getting enough of a leak there to cause this condition? I would think it would at least keep running with a leak but would run rough or erratic. Any other suggestion?
I did replace the needle and seat with Tecumseh OE parts. I have checked and cleaned the idle jet and all is good there. How sensitive is the float level? I have it set at 11/64" per manual which is nearly level/parallel with the carb body. I'm wondering if I need to replace the seat again as I didn't really clean the cavity with anything other than carb cleaner so maybe the seat didn't seal well with the carb body due to corrosion. Only thing I think could be the problem. Wish I had a clear bowl I could install to actually see if the float valve was operating properly.Personally I have yet to find one of those aftermarket clone carbs that will work on the older Tecumseh engines. You say you have cleaned the carb, but did you replace the float needle and seat? Tecumseh part number 631021B. $5.00 part that if done right fixes 80% of the time. Here is the procedure I use.
Needle and seat replacement.
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. Next check to make sure that the float does not have any liquid in it. If it does, replace. If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: On the side of some Tecumseh carbs you will find a plastic cover. Under this cover will be an idle jet. Remove it and check to see that the jet is open both horizontally and vertically. You should be able to push the old float needle wire through the vertical opening.
When you look at the float it is slightly inclined or closer to the carb body on the free side of the float.As I stated in a previous reply, I like to set the float level slightly on the rich side, which means a little lower on the free side of the float. If you replaced the needle and seat already, I see no reason to do it again.
Also, how tight due you torque the float bowl screw/jet? I assume you tighten until you feel the bowl make contact with the bottom of the carb body / pedestal, correct?As I stated in a previous reply, I like to set the float level slightly on the rich side, which means a little lower on the free side of the float. If you replaced the needle and seat already, I see no reason to do it again.
