2ball
My dads John Deere X330 wont start. Its about 3 seasons old.
a couple cuts ago it quit running mid cut and he couldn't get it started.
The air filter was caked with dirt. I cleaned it and the mower started up and ran.
2 weeks later the mower cut out mid cut again. air filter was still clean. It would not start again.
I can get it to start and keep it running with starter fluid in the air intake.
What is my next step?
Clean the carb?
What is the likely culprit?
engine
Clean the carb?
engine
| Briggs & Stratton 44J677 | |
| gasoline | |
| 2-cylinder | |
| air-cooled vertical-shaft V-Twin | |
| Displacement: | 724 cc 44.2 ci |
| Bore/Stroke: | 3.12x2.89 inches 79 x 73 mm |
| Power (gross): | 20 hp |
