Sears Craftsman Mower Won't Start??? Funky Switch Circuit Diagram!!!
mr. sky I meant to look in the back of the owners manual it has the circuit diagram. I attached the pdf. The circuit wires are color coded and their connections. Hope I was of help.
First of all thanks for the pdf, however,I cannot see any color coded wires to connections.
pdf is all black and white. Could be a malfunction at my end. But does anyone else see
color coded wires. I am using Adobe 9.4 to view
If you look on Page 58 of the pdf.... you will see that the wiring is Labeled as to its color... :smile:KennyV
Thanks for the the correction, your assistance was greatly appreciated. Kenny thank you also
Sorry I forgot to mention they were merely labeled with their color codes. Glad I helped.
