Build ate: 4/17/2018
Short version: intermittent starting issue. It is a compression issue as the starter spins the motor fine without the plug. New battery and starter.
One shop I spoke with said it is part of the cam shaft (like my B&S is) while others say there is a spring and lever that can be replaced. However, I can't find a schematic that shows that.
The shop manual doesn't say anything about repairing the ACR, but talks about it.
Any advice? Part numbers?
Stupid question is, will i have to remove the valve springs (don't have the tools, nor do i want to get into that)?
Regardless, i would like to know the above so i can either do it myself or discuss with a shop.
Thank you.
Thank you.
