I have seen many fine running engines with clear filters that look empty. The problem is when the customer sees the phenomenon. He becomes so fixated on it, that anything that happens, in his mind the fault is fuel starvation, and he spends a whole lot of time and money in that direction.Clear filters are nothing but trouble.
So I stopped selling the clear ones. They were nothing but trouble.
Try loosening the cap when it starts to die.
Also, is the tank higher than the carb?
If you disconnect the fuel line at the pump, does the fuel flow? If so, drain it into a can and watch things flow.
Is the tank clean, and the screen clear?
Firstly the impulse signal on a twin is a lot less than the impulse signal on a twin
Twin tank set ups are known for debris getting clogged at the tap.
So get some sort of spare tank, pinch it off your push mower if you have to .
When the mower cuts out slip the alternative tank onto the pump and see what happens
Problem goes away = debris restricting fuel supply to pump.
Alternatively you can blow back through the fuel line with the fuel cap off both tanks really hard
Again problem goes away then debris in the fuel lines
I have taken to fitting fuel filters before the tap on multi tank set up to cure this problem
As no one has pot an answer to your other post would you be kind enough to go back to it and in the lower right corner there are 3 green words
Report - Edit - Delete
Hit the delete button to remove the thread
