Tailhunter
- Sep 15, 2020
- 1
I have a 2 year old Cub Cadet RZTL42 mower. I was using it yesterday and the blades shut off and would not turn back on. I bypassed the seat switch to make sure that wasn't the problem but it they still wont turn on. I pulled the switch and tested it with a multi-meter and it tested fine. I checked for power at the PTO and I have 12 volts on BOTH pins. What does this mean? I believe I should have 12 volts and ground correct?
