kcareabroker
- Sep 8, 2020
- 6
Hello,
I have an about 15 year old John Deere LA 120 that has up to this point been a good running lawn mower with some typical maintenance done. So for that I am happy. Starting last fall through about a month ago, the engine began acting like it wanted to die while mowing. I could use the choke to keep it running and eventually it would come out of it and run normal. This usually is after it is started and ran for a few minutes until it was running for about 15 minutes. It was easy to start and occasionally would do it after the mower was running for awhile. The last time I ran the mower it acted like it was running on one cylinder with limited power and an obvious miss.
What i have done so far:
replaced spark plugs
replaced carb with a new one
replaced fuel pump
repaired small hole on the vacuum tube that goes from the valve cover to the fuel pump. I plan to purchase a new one but I know this one isn't leaking at the moment.
The engine seems like it isn't getting gas. With the air filter out, I can spray some start fluid in the inlet for the carb and it starts and idles fine until the spray is consumed. The carb fuel bowl is full of gas. I have pulled the fuel line off and while turning over the motor, gas does spurt out of the fuel line. Gas will also trickle from the inlet of the carb if I pull the fuel line off.
The engine is getting spark to both cylinders. I have pulled both spark plugs and left the wires on having them fairly close to the motor while cranking over and both deliver a decent spark.
Not sure where the heck to go from here. Not ready to give up but running out of ideas since the motor seems to be getting, air, fuel, and spark. Any ideas?
The motor model number is 441677.
replaced fuel pump
