- Feb 19, 2020
- Threads
- 114
- 12,445
Mower is repairable, It just not as end user serviceable as some are. Most ZTR and riders have sealed hydros. Doesn't mean they are not serviceable; it just that they must be remove to do so they are sealed as preventive maintenance measure, mainly to keep water and dirt out of them. I recently serviced a Tuff Torq K46 sealed unit. The oil fill had failed and oil looked like thinned peanut butter due water getting into the hydro. THe unit must be removed and turn upside down to drain the oil and replace the internal oil filter/strainer. Plus the oil pan is pull off upright the brake puck and a magnet or two falls out; upside down they don't.It is called a disposable mower .
The main problem I see would be the steering on SX54. I have seen one in person yet but looking at the IPL it looks rather involved repair wise. I prefer lap bars over this type of steering.
Sealed bearing with good grease and the appropriate amount of grease will last several years, just depends on usage level. I just rebuilt the spindles on 2019 17RIEACZ010 that the customer is using commercially. Of course they going to need more servicing.
Even the taper bearing spindles will still need the cones and cups replace sooner or later.
