Mower King
Check your battery, I mean really check it, with an ohm meter as you engage your starter and read that #, what is that #?I checked the valve clearances and they're good per the manual. Anything else I should check?
If battery tests good, check flywheel key, if it sheared, it moves the Ignition timing and it can "kick back" when you try to start it, kinda like you are describing....but 1st, BATTERY!
