- May 6, 2010
- 12,015
Fish I think he is referring to the fact that I determined that he had installed the MDI ignition system which is an electronic spark advance module system that was originally fitted with the CDI fixed timing ignition system, and the two systems are directly not compatible. So by changing the ignition system he created the misfire issue that the dealer overlooked.????
