LT155 Deck Vibration/Noise
cruzenmike
Hello All.
So, I am a few weeks into using my recently acquired 1998 LT155 and am having an issue with the deck vibrating excessively and making a noticeable noise when running. The engine is running smooth with the PTO disengaged and does not surge or miss a beat. When the deck is engaged, I can not only see the PTO level vibrating a lot, but I can also feel the entire mower shaking and there is a "pulsing" hmm coming from under the mower.
When I purchased the mower I replaced the deck spindles, idler, pulley, sheave and belt with genuine OEM parts. I also removed the TriCycler kit and equipped the deck with the the OEM High Lift Blades as I only side discharge on my lawn.
I initially noticed a difference in the vibration the first time that I used the mower with the repairs made, but it seems like it is vibrating more than ever and the humming from the deck is louder as well. The blades are free of damage and are not bent.
I am not used to or very familiar with mechanical PTO's and am wondering what all could be causing this problem? Since there isn't a typical tension spring pulling on the idler arm, could it be a problem with "weak" spindle breaks which I believe to be what applies the tension to the belt?
I appreciate any help or insight that you might provide.
Mike
Mower King
Hello All.
Mike
So you're saying you don't have an Electric PTO but, a lever and cable that you apply to manually engage your deck?
Hammermechanicman
The 155 is not an electric PTO. Mechanical lever moves pulley to tighten belt. Might want to check deck belt tension with lever engaged. Not enough tension can cause deck vibration
Vibratiopns are usually caused by
1) Blades bent or out of balance
2) DAMAGED BLADE SPINDLES
3) DAMAGED PULLEYS
4) damaged belt
If the tension in the belt is not enough then the blades will stop spinning or radically slow down in heavy grass.
The brakes do nothing but stop the blades rotating ( legal requirement ) and this has a secondary function of concentrating the belt slack at the engine pulley.
If the brakes are touching the pulleys with the blades engaged they need to be adjusted .
Also check the holes in the tension lever that activates the brakes, they do flog out oval so the brakes can drag but this is rare on JD decks.
cruzenmike
Thank you for the replies. I will go ahead and check all of these things. Seeing as most of the deck parts are new, and since the problem was only really noticeable after I put on the high lift blades, I am going to try to check the blade balance and possibly even swap back to the mulching blades and see if the problem persists. I am quite certain that the linkage for the PTO is okay as the posts align with the holes perfectly when installing the deck.
I will investigate and report back.
Mike
cruzenmike
So I took the high lift blades off today and I am quite certain that one of them is off balance. These blades are brand new and used only once. And I have not hit anything with them. I am quite disappointed with this considering that I am buying the OEM parts from the dealer. There may be some error in my looking at the balance as I am just using one of the Arnold blade balancers and the new Deere blades have the star pattern making it hard for them to center on the top of the cone. I did put the TriCycler mulching blades on to the balancer and they appeared to sit level. One thing that I did also think of is that between my 2nd and 3rd cut, I did raise the engine RPM about 200 to get it up to factory spec of 3400 top no load. It is now starting to make sense that if there was a balance issue, the added engine RPM at full throttle would make that vibration more severe and the noise coming from the deck louder.
I am going to give the John Deere Dealer a call tomorrow and explain what is going on and see if there is anything that they can do for me. I doubt it since the blades are used now, but at the very least I can look into a different blade. I have researched a found that Oregon makes a "100 Series" blade which has an extra long cutting edge as well as a low lift sail that extends along the whole back of the cutting edge instead of just the tip being turned up. I guess in all there are about 4 OEM blade options and at least 4-5 aftermarket ones. I want to find the best balance of deck noise, minimal power consumption, cut quality and clippings dispersal. This might take some trial and error. In the end, I hope that whatever blades I try, the noise and vibration goes away.
Oh yeah, I did check the pulleys, idler and sheave and they all looked okay. Belt is also good too. So maybe it was just the blade.
Somewhat dissapointing
in the past 7 years I have only ever had 1 set of blades that were out of balance from new
I have the same balance checker as you are using, most just use a nail on he wall
What has caught me out was a couple where the flutes were not identical at each end and the supplier replaced them without question.
cruzenmike
So, I took the high lift blades up to the dealer and they exchanged them without issue. I have not had a chance to put them on but I did put the wavy mulchers back on, all sharpened, but without the deflector/baffle that is part of the TriCycler kit. To be honest, the mower did very well with this configuration. Not only did it cut well with no clippings left uncut, the deck was much quieter and smoother than with the high lift blades. I also feel as if the discharged clippings were smaller as well; likely the result of a much longer cutting edge and wavy blade design.
This has me excited about the though of a Gator Blade maybe improving my experience with side discharging. I would probably go with the G3 which is still only 2.5" wide and has about a 3/4" lift on the back side. I believe that these blades will do well as they too have a long cutting edge but will also rob the engine of less power with their slightly lower lift compared to the OEM high lifts.
If I get a change to pick the blades up J will report back. I look forward to trying all the various combinations of blades and chute blockage when leaf season comes.
Mower King
Yeah...you gotta try a few things and a few different things to find out what works best for you and your mower!
You can quote me on this "just because it's new....don't mean it's good"
cruzenmike
Just wanted to give an update on the blade and deck situation:
I have fitted the LT155 with some Oregon Gator G3's this past week. I have mowed with them a few times and have to say that there may be something to the vibration that comes from the higher lift on the blades. I do not notice any abnormal or significant vibration/noise when using the wavy mulchers. With the G3's I get a little bit of vibration and some droning noise. The cut performance of the G3's is okay, but I am realizing that much of my experience with this machine is being driven by my often-times dense and tall turf along with the machine being underpowered. I can honestly say that the best overall cutting performance is with the wavy mulching blades while side discharging. I still keep experimenting with different cut heights and blade types. No matter what I do I still get a nice clean and even cut with the baffle/chute block removed.
