Hammermechanicman
- Jan 10, 2020
- Threads
- 56
- 3,528
The plugs you are running are probably ok. You most likely did not have enough air flow and the engine was hot enough to boil fuel in the carb. Taking off the hood allowed enough air for the engine to run cooler. Color doesn't really matter. When the outside temp drops 20 degrees probably can put the hood back on and not have a problem.
