I'll check Thurs when I go to work to see if we have the right model, we have a couple bad B&S engines in boxes in the back.I need a flywheel for a B&S Vanguard engine. B&S nor any of the regular parts outlets have one. Engine model #350477 1118-E1. Flywheel part# is 808768. Thanks
Recheck engine numbers aboveI need a flywheel for a B&S Vanguard engine. B&S nor any of the regular parts outlets have one. Engine model #350477 1118-E1. Flywheel part# is 808768. Thanks
I checked those 2 B&S engines we have for parts, they are NOT a Vanguard engines, they are 27 hp Commercial Turf. So I looked up that Engine and they make 4 different flywheels for that model #, 3 are NO longer available and the # you gave is one of them. 1 is available still but it's # 844819 and is for a recoil / rewind start engine. If you could find someone that had that 844819 flywheel, compare it in person and....if, BIG IF, the only difference is timing keyway, you can still use it.....I can tell you how! Good Luck!Sorry model is 350447 1118 E1 flywheel # is correct 808768. If you still have it I will take it.
