Congrats on the 152! Definitely the model to get for commercial use. I use mine residentially (2 acres once a week). 152 is much beefier than the Pro Turn Z.
I don't know if it's a great deal beefier. They are both commercial grade. I think the 152 might has a little thicker steel in the deck construction, but otherwise those are the same. It might have bigger tires? It does have an upgrade to the drive transaxles, so that's probably a bit more durable. But whether the engine is really better, IDK. The seat is definitely an upgrade, as I said. Otherwise, as far as I know, those are the only differences. I'm pretty sure the Z will do 95% if not more of what the 152 would do, in terms of longevity and durability. You've got a mower that is seriously over kill for 2 acres/week. Enjoy it, you'll have that mower for a long, long time!
