Then I discovered the actual problem. When you mount the carb on the engine, you push the outlet of the carb onto a rubber o ring. The o ring is mounted on a plastic part that conducts the fuel air mixture into the engine, and that plastic part was broken.
This isn't quite obvious by just looking at it ---but I'd check it with some care since it can be the source of your problem.
Was your plastic part cracked? Was it simply blocking the mixture flow or redirecting it somewhere? I am assuming you replaced the part? Do you happen to have a URL for a replacement? Or just the name? Thx >>
This plastic part, which the rubber o ring fits over, was cracked/broken all the way around so that it came away in two parts when I replaced it.
I had another decomissioned engine of the same type, so I simply took that part off the decommissioned engine,
I had spent a LOT of time looking for other reasons the engine wasn't getting fuel. Quite possibly this defect is rare, but after you've tried more common reasons for the engine not getting fuel, I'd look carefully at this part, since I guarantee you it's a possible cause for the engine not to run.
When you have the carb off the engine and you can see the rubber o ring, that's a good time to look carefully for a crack in that part. There was one other part that blocked your view of that part, but that could be removed fairly easily.
I was really quite proud of myself for finding this defect, which no one had suggested.
I'd be interested in finding out how common this problem is. How often is this a cause of an engine not running?
This is on the B&S carburetor part 799868.
The part that was broken was the intake manifold, part 794305
Shop OEM replacement parts by symptoms or model diagrams for your Briggs and Stratton 12F802-2021-E1 Engine!
www.ereplacementparts.com
When you take the carburetor off the engine, you can see the rubber o ring that is on the end of the intake manifold.
