Shootertexas
- Jun 18, 2020
- Threads
- 5
- 26
On going Surging issue. I have a 44N677-0005-G1 with a 594207 carburetor.  It belongs to friend of mine.
It had an issue a few weeks ago with the solenoid not work and not allowing the engine to start. Once it was freed it ran great. Fast forward 2 weeks and running it to mow about 2 acres he calls and says it runs very poorly. Come to find out the needle was allowing gas to flood the cylinders. Brought it my house, pulled the plugs and changed the oil & filter as it was contaminated. Immediately started it and it ran fine. Removed the carb and cleaned it. Replaced the float, needle, main jet, bowl gasket and fuel pump and vacuum line.
It is no longer flooding the cylinders as I preformed a pressure test with a thumb pump and it held 7 psi.
Now the problem, while it will start, it surges wildly at all speeds until I push the throttle up to choke it ever so slightly at which point it runs smoothly. Any more choke and it bogs down. I have removed and replaced it several times and cleaned all the orifices i can see multiple times. The emulsion tube orifices are clear.
Any ideas of what to do ???
