Quad Disk upgrade to high
AusieAfrikaner
Hi all,
Intro: I bought my mower 5yearsago in South Africa, Trimtech chassis, 18” single blade with a 650series 190cc OHV Briggs & Stratton motor. On recent years I moved to Australia and now need to replace the blade, initially when i bought the mower I wanted to upgrade to a tri-blade disk setup once required, but due to logistical complications this was not a viable option so i searched for local 18” disk options that would suffice and found a suitable option with the accompanying new Boss.
Ordered online fitted parts and found that the new setup sits about 15-20mm too high up in the chassis. It all works well however im limited in the cut length and cannot cut enough as the chassis starts scraping.
Being technically and mechanically minded I have come up with a few potential solutions, i.e adaptor plats, boss extensions, shaft extensions, however I wantbto avoid adding too much additional rotational mass as The additional weight of the disk is noticeable on startup.
Has anyone else encountered a similar problem and what was the solution you used? I’m looking to use the mower at least for another 5years or until I’m on a larger property where I can justify upgrading to a 19” or larger.
Don't get discouraged, bertsmobile is in Australia and it's night there he should be able to help, we pretty much don't use the disk blades here in U.S.
This comment will put you back to top of threads.
OK
Welcome
Because of the large number of fully imported USA spec mowers sold down here we should be able to find you a replacement blade to fit the original blade boss.
Allwe need to know is the diameter & shape of the hole in your original blade and if it is stepped or flat.
If you really want to go the blade disc route then every brand of mowers sold in Australia has an 18" cut model except Honda who do 19" as their smallest cut
Every brand also has a Briggs & Stratton engine either as an alternative or only power source.
SO the first problem is the diameter of your crankshaft 1" , 7/8" , 20mm or 25mm as your engine could have any one of the 4 .
Next, what blade disc did you buy & who did you buy it from ?
We might be able to find some stepped blades that will lower the cutting height a bit.
Next what is fouling on the mower chassis, the blades or the blade bolts ?
Most blade dishes except Masport are cupped and they all fit cup side down so the blades are lower than the mounting bolt for the disc to protect the bolt from being rounded in use.
On top of that some blades are flat while others are stepped and all the steps lower the blade height .
These are the Blade holders used on most local mowers;
The full disc ones all use the 3 bolt mounting except the Victa one
If you have a 7/8" shaft I would recommend the following disc which sits on this boss and is held on using this washer & this nut with this blade set
If money is tight then buy any dead 18" Victa with a B & S engine off ebay and pinch the blades & mounting hardwear off it.
Most regional tips sell the mowers people toss out for a very small price if you are not in one of the major cities.
OK
Welcome
Thanks for jumping in, I knew you would have the answer if you saw the thread !
