trobinson017
- Sep 8, 2011
- 8
I had a problem last month with my mower, a Craftsman Eager-1, about 5 yrs old. It was difficult to start, ran rough, and would conk out after about 3 minutes. I rebuilt the carb with a proper kit and replaced the air filter and cleaned the muffler area. Now it takes about 30 pulls to get it going. Once it starts it runs strong and even. No sputters, nothing. There's no gas leaking anywhere. The pump bulb is good with no cracks. I went and bought a new plug and gapped it. Still no easy start. Today, based on a tip I read somewhere in these forums, I pulled the plug (wet and gas smell) and put some gas into the cylinder hole and replaced the plug. I had primed and tried to start it about 30 mins before doing this. After replacing the plug I didn't prime it. The mower started after about 5 pulls and ran strong and smooth.
So, what do I check now? Could there be crud in the fuel line (?) after the carb? Is there a fuel pump on these small mowers that needs checking? FWIW, I live in Florida and mow year 'round. No mower down time. Also, all these tests have been with fresh gas and even some Stabil ethanol treatment at different times. I can't afford to take it to a service shop.
