Mantis Toebogon
- May 24, 2020
- 3
Hello everyone,
I can't seem to find a post where it won't even click so here goes. Sorry if this has been asked, I will delete if informed.
1: Tried to jump start as battery was dead. Would jump start and as soon as I took off jumper cables it died. Tried again and won't even jump start.
2: When turning key to start there is no click or hour indicator at all.
3: I have power to the starter relay with the key off and with the key in the on position. No power to starter side but can jump it with a screw driver and get spark. The starter turns but sounds like it won't engage or turn the motor. Just sounds like it is spinning.
4: I have tested the ignition switch and it checks good. I've checked voltage at everywhere I could think of and google. Fuses are good and even replaced them to make sure.
I believe this is a 02-03 L130.
