intruder1500
Last couple of times went to start the subject ( and it has been a 1 pull start for 20 years ) and it wouldn't start. First time I primed the crap out of it...pulled the plug and it was dry after a dozen pulls. Pulled the air filter and it started on the first pull. A week later same problem....multiple primes....pull the plug and its dry. Poured fuel down the carb throat and it stated after a couple of pulls. My first thought was that the carb jet was plugged but after it starts there is no issue. Thinking now maybe its the primer bulb or hose thats the issue. Any other thoughts out there?
