cruzenmike
- Feb 10, 2017
- Threads
- 60
- 859
You will see a ton of people using an "impact wrench" while changing their blades but this is NOT advised. A torque wrench should always be used to tighten the blades back down. Follow your manual for the torque spec and whether or not anti-seize on the bolt threads is needed. ALWAYS start your bolts by hand; once started you can switch to the torque wrench.
Why not use an impact wrench? Even a low voltage cordless impact wrench can exceed the torque rating and risk stripping the threads on your spindle shaft. A pneumatic impact wrench typically exceeds the torque of cordless ones.
While changing blades without an impact wrench is certainly more difficult and time consuming, it still can be done and done safely if directions are followed and precautions are taken.
