shibbershabber
JD L100 with 17.5 B&S
Used weekly, works great... at one point I thought the solenoid went out as I had to start shorting it to start... did that for a while with no problems. Finally ordered a replacement...
Replaced solenoid and battery... wont start with the key, but still starts and runs fine jumping the solenoid.
Today... jumped solenoid and was getting ready to mow... but at idle it started to lightly surge and then die. Got it to start again, put it full throttle and it started to surge again, engaged PTO and it died.
So, surging idle and dies under load.
Now.. wont start at all.
When I short solenoid it still turns the motor but it will not start.
What I know:
Have spark
Have fuel (though maybe not enough? when I dc the fuel line at carb, while cranking fuel trickles out.)
brake switch is good
PTO switch is good.
NO voltage to purple wire at solenoid
Thoughts?
What I know:
Have spark
PTO switch is good.
Thoughts?
