jakesmurray
This motor is on a John Deere 112L riding mower. We bought it at an auction for $90, they said it would start, but wouldn;t keep running.iWell. it will not even start for us. I tried to start it as is, and nothing. Then I did the following:
-New spark plug (gapped correctly
-New air filter and precleaner
-New oil filter
-Changed oil with SAE 30
-Took off carb, cleaned it inside and out thouroughly
-Replaced fuel filter
-Emptied gas tank, then took it off the mower and cleaned it really well
-Refilled the tank with brand new gas
Here's what I know:
-It has spark
-It has good compression
-The carb is getting fuel
I can tell you that when it is cranking trying to start, you can kind of hear an abnormal clanking noise- like something is rattling inside the engine. Could that be the problem?
Please let me know if you have any suggestions, as I would really like to hear this thing run. Thank you!
-New oil filter
Here's what I know:
-It has spark
