Bought this new early in 1990 and it has been in use ever since, but generally light use and with relatives. I will get it at least yearly and 'fix it up' again, but it is still original - the engine has never had any internal repair, not even a new carb or gas tank. The major problem at this point is the blades are obsolete. I have to get a generic 20" blade and adapt it - this is getting old. There are two reasons for needing a special blade or adapting one - the deck has a round 'plenum' that is meant to isolate the rotating air and increase the effectiveness of bagging/discharging - no mulching really possible, and it is the sweetest little bagger I have ever seen - manicures the lawn. Anyway, the plenum wall comes down so far a straight blade will scrape it. so, the original blade has a 'dip' on each side to clear the wall. Also, the blade adapter has locating pins for the blade but they are closer together than the slots for them in any generic blade. I found that using a 20" mulching blade that angles slightly down on each side clears the plenum wall, but I have to take the Dremel and round file to the slots to extend them toward the center. The center hole is large because its a generic, so this really doesn't leave much steel between the extended slots and the hole, which has a filler plug. Mounting the blade is somewhat tedious because of the loose fit from all this hand work, trying to get it centered - not the best solution. I tried to find an old-style blade adapter that would work with it to no avail.
Since my SIL has it now and is not known for taking care of things, every year I figure is going to be its last, but it just keeps working. Doesn't use oil and doesn't smoke. Never had to put a lower seal in it (yet). It has the 3.5 HP B&S but it is a premium version with quiet muffler - that's still original too. I have replaced the wheels, grass bag and starter cord. They called me once and said it was 'squealing'
so I went over there expecting to see a rod through the block but it turned out to be the starter clutch - all I did was lube it but when you have a really old mower, funny things begin to happen that you may not have had trouble with before.
I'm afraid it doesn't look this sharp anymore but it is still out there cutting grass. The blade shown is the last original one I could find, about 15 years ago.
