Evpena87
I have a 32cc leaf blower that I replaced the short block on. I finally got it together but it wouldn’t start. I sprayed carb cleaner into the carb and it turned on right away. It ran for 5 seconds to reach full throttle then shuts off. I did not touch the throttle in this process. I replaced the carb thinking it may not be getting fuel but it is acting exactly the same way.
Any idea that I can try to fix this issue?
thanks
thanks
