Chris Parman
- Dec 22, 2019
- 112
On the contrary, At around $60 (OEM part) its more cost effective to dissemble and clean it up for free (at first try). If you have Skills and you are careful you can by a Ultrasonic cleaner (harbor fright) use that to clean all the parts. Think of it this way, if you at least try to rebuild it you will learn something about the Carburetor. I don't think the mower is that old it just needs a good cleaning. It just takes a little more effort and skill to go beyond just being a parts changer. There are plenty of U-tube videos out there and read the post by robert@honda called "How To Clean A Honda Carburetor" that pertains to carburetor cleaning in case you choose this route. I've been rebuilding these type of carburetors for years, mostly the commercial grade carburetors which are slightly more complicated. One note to mention, you will have to take out the Jet and emulsion tube prior to cleaning to do the job right. The key areas are the passage ways in the main body, Jet and Emulsion tube. Those single areas or a combination of all three lead to surging issues in one form or another.Classic surge, won't idle. Doing this for my daughter's boyfriend, he bought the mower last season, put it away without draining the fuel or using sta-bil. I'm sure the inside is totally gacked and sounds like it's cheaper and easier just to replace the carb. Small engine carbs are so cheap now, doesn't make sense to mess with them.
Cheers, be safe everyone!
