- Nov 29, 2014
- Threads
- 65
- 24,995
They are all easy to use but a PIA to set up.
All of them are either a set of data bases or spreadsheets with fancy dancy data input windows & output windows .
BEhind that are just cell calculations look ups and relations rules .
I find it too cumbersome to use as intended.
So I use one of the business templates that does not have inventory ( Accountant , Doctor, etc etc ).
That way the printed invoice has billed hours & I add the parts as individual line items .
IF you set up as a repair business then you have to add all of your parts inventory, including the parts you have bought for this job, before you can bill the customer for them.
Then you have to remember all of the parts numbers & I find that a bit onerous .
IT also can not handle things like parts that have 2 or more numbers like an air filter which can have a JD number, an MTD number , a Husky number & a B&S number .
Then there are pulleys where you need to bill the customer for a Toro part but you fitted a Husqvarna one that is the same size .
Same story for belt where I fit a Hustler belt which is a 1/4" shorter to the Time Cutters but 1/2 the price.
On he invoice I need to show the Toro number but the softwear will not allow a different description to the one you entered in the inventory .
Thus the use of a service invoice and the keeping of 2 sets of accounts .
In my carbon book I can write the actual part used on the back of the opposite page so I know I fitted a 265-918 belt while the invoice shows a 954-0441 belt .
Then at a latter date sit down and enter what I need to from the carbon copy into the computer so I have a computer record for taxation purposes to do all the adding & subtracting .
For parts the computer I just have three account names ,parts bought , parts sold and parts inventory .
So all of the bills from the parts suppliers go into parts bought account and all of the parts used come out then the balance is inventory which goes onto my tax return.
The other problem is I do parity pricing with one of the bigger internet parts retailers so my selling price continually changes .
So again I have to either allow overiding which is not a good idea or continually change the selling price every time I do an invoice .
Then there are trade customers which get different pricing again but not a std discount rate .
I really do not need most of the information that these applications produce except for lodging tax returns .
Charts , graphs & tables are fine if you are full time manager but as a sole trader a bit of overkill for me.
I use a lot of grab packs for cube carbs so end up invoicing for a "rebuild kit " or "diaphragm & gasket kit " when I keep neither in stock but have no intention of invoicing for the actual parts used as individual items.
The other trick is to set up your business file then duplicate it and work on the duplicate so if you have to change things latter you have the clean copy with no data in it .
Again work on a copy of that file , it might take a dozen or more tries till you get it right but it takes a lot less work to import a customer list or accounts list than it does to re-enter all of that information time & time again.
Use a fresh file for each year calll them PT 19-20 , PT 20-21 etc so if you need to change them you can do it easily without having to go back to scratch again.
