honda hr215 hxa
rml6093
Check the condition of the bearing in the blade clutch. If may be failing.
Do you have any instructions on that hahaha
and today I got them to engage by slowly engaging the blades but then I stopped to clean out under the deck (I don’t have a bag) and when I tried to engage them again the engine cut off on me and I wasn’t able to get them turning again... so looks like I’ll be clockin in some shed time
HarmonySeeker
You do have a blade clutch on the unit, right? If so, remove the blades after pulling the spark plug boot for safety.
Now remove the big bolt in the center. That is the blade clutch.
Note there is a bearing surrounding that bolt.
THAT is the blade clutch bearing.
See if it spins freely.
If not, replace.
rml6093
If not, replace.
Thanks will do! And yes it does have the blade clutch
rml6093
Didn’t even check the blade clutch went to the simplest troubleshoot and it was as simple as tightening the blade cable. Fixed!
my only problem now is my surging issue on start up???‍♂️
HarmonySeeker
Glad it was a simple fix. I haven't had to deal with a surging issue yet as I am still putting the blade clutch back together.
HurstGN
If you had the carb off, it's possible a gasket is not installed in the proper orientation and an air passage may be blocked.
rml6093
I’ve never had it off. I took the bowl off to see if it was dirty and also had the throttle stop screw off to clean the jet under it
HarmonySeeker
There's top-notch experts here on this site, no doubt, but maybe this is the trick:
rml6093
Are the bolts to get the blade off reversed or the normal righty tighty lefty loosey
tadawson
I had this problem on an HR215, and also tried cleaning the pilot jet to no avail. I think it shrunk due to being plastic and age - and no amount of cleaning woueld help. I replaced it, and have run flawless for close to 10 years, with no other changes or cleanings to the carb. The want a ridiculous amount of $$$ for such a small plastic part, but it was worth it.
Ultimately, both the surge and the stall are due to the engine running lean at low power (IE not yet on the main jet).
