Ferris is2000z governor linkage diagram 30hp vanguard big block
Andys Tree
I have a 2010 is2000z model5900811 with a 30 hp briggs. I just installed a cam,lifters,sump cover,and a new fuel pump. When I took the governor arm off to replace the fuel pump I thought I would remember where it goes and where the springs go but i forgot. So I'm curious if anyone can find a diagram or a picture of one so I can assemble it correctly. Any help is greatly appreciated. Thank you
Model 542777 type 0113-e1 code 09111712
