Tinkerer200
- Mar 14, 2015
- 913
Good to know, thanks. I'll try and get the flywheel off without using the chisel and hammer. Maybe I finally invest in a proper puller.
The proper puller is cheap, a lot cheaper than a new engine. I have photo of using the pry and hit method resulting in hole in thin casting area under the flywheel as mentioned above by StarTech - not worth the chance and you can make your own puller for that matter.
Walt Conner
