Mr.Quebedeaux
I changed the upper and lower transmission belts because I noticed a good bit of slack in the upper one. The little thing that slides up and down on the pulley moved freely. It is not stuck.the lawn mower slowed down a good bit. But I still only have one gear.only one speed even though I switch gears. I stay the same speed. Any information would be greatly appreciatedI recently bought a troy built pony riding lawn mower used. It is pretty old but well kept up.The guy I bought it from changed two belts just before I bought it from him.when I put it in granny low it drives fine. When I put it in 2nd threw the highest gear It's speed is always the same. Which I think it is stuck in top gear. I can not get it to shift into 2nd 3rd 4th an so on. I mean it shifts into those gears but they all go the same speed."fast" why am I not able to go any other speed when I shift into these other gears.
