Mower runs for a couple of seconds after starting, then stops
Mbcarter967
My mower won’t stay running. I recently did some repairs by replacing the intake manifold and gasket between the breather and the carburetor. My mower ran for a few minutes while I was cutting the grass, but it would try to die every time I squeezed the self-propel lever. I eventually got tired of dealing with that, so I took the carburetor off and cleaned it to try to fix the problem. Now, it won’t stay running. Any idea what could be the problem and how to fix it? Thanks!
We would be better able to help you if we knew what engine you have including the model number from the engine. Some engines have a float seat that will swell if exposed to carb cleaner, and some of your symptoms may relate to that happening, since it can slow the flow of fuel into the carb bowl, allowing it to run until the bowl is empty and then has to refill to restart,
Because if you have a mower that you have to prime to start, what a primer usually does is pump a couple squirts of gas into the throat of the carb making it easier to start up.
And since you said that your mower only runs for a bit then shuts off, if it's the type of mower that you have to prime it's probably just running on the fuel that was put into it when priming.
Therefore it would probably be an issue with the carb causing it to not suck up the gas from the tank, more than likely a clogged port as @ILENGINE stated.
I would be looking at the float level in the carb as IL stated, not the primer. I suggest you remove the carb again and clean it one more time. Replace the float needle and seat and make sure that when you set the float level make sure that it is not higher on the side opposite the float pin, but either level or slightly lower. Primer has nothing to do with it.
