BashRipRock
I inherited this Generac Generator. It is a Generac 4000XL Model#09777-1 with a sticker showing 7.8hp. I can see that it is 4,000 watts. Upon receipt, I was able to get it started and it ran for 5 minutes before it ran out of gas. From speaking with the mother in law it hadn't been used in 6-8 years. So I changed the plug, cleaned the carb, new air filter, fresh oil, and installed a new fuel line. With fresh gas, the thing doesn't want to fire. Then on the next pull, the rope broke and I went flying across the garage. Feel free to laugh because I did! I just spent about an hour on Google and scouring here on the forums looking for information. I can't find any information on this engine. The online manual just has the Part# for the engine which shows "no longer available." I obviously need a pull rope assembly and I would think that there is some type of an ignition coil on here? I really can't troubleshoot much further until I replace the pull rope. I would appreciate any assistance I can get. Fairly mechanical but most of my tinkering has been on Tecumseh and Kohler. Have a Briggs on my air compressor. Thanks again.
