6010fd12
Found a thrown out leaf blower and decided to try and restore it. Model# 358.794764
I don't have much experience working on small engines and this is for sure my first time owning a two stroke engine. It turns over fine but feels like it has weak compression (imo). I double checked with a gauge and here is what I got.
First Try
Second Try
I have replaced the spark plug and the carburetor as well as put some new fuel/oil mix in. While changing the carb I noticed that the fuel filter was either clogged or not tight enough on the hose because priming the bulb would not suck fuel in. So I replaced it and that allowed me to prime the carb.
I tried to turn the engine over and still nothing. I looked in the cylinder again and I noticed there is some type of muddy liquid(dirty water?) inside. I cleaned it off by sticking a towel inside but after turning it over again the liquid reappeared.
I had some more time this weekend to look over the engine and I found another problem with it. The cylinder head was unattached from the crankcase.
This probably explained the lack of compression that I felt and explains the muddy liquid. I took apart the head and tossed it in the ultrasonic cleaner. I replaced the piston ring and a couple of the gaskets by the head and carb. There was still that liquid resting in the bottom of the crank case so I tried to pour out as much as I could before reassembling the engine.
I poured a bit of 2 stroke mix into the cylinder and this time the engine actually ran for a couple of seconds before dying. I repeated this a couple of times but it seems like it either won't suck fuel in or maybe there is still water at the bottom of the crankcase. Any ideas?
First Try
Second Try
