Sears Eager/Tecumseh Compression
Jeffalex2
My neighbor gave me an old edger with a 3hp Eager on it. Compression check wet with carb off is only 75lbs. Valves look good... should I put rings in it? See how it runs as is?
Thanks!
dougand3
I'd just run it. When I looked to re-ring a 5.5hp Tecumseh TVS120, the ring set was over $40. Plus, the cyl could have worn and there be little benefit with new rings.
Fish
Compression readings are usually worthless on small engines.
Scrubcadet10
Moderator
Staff member
:thumbsup:
A leakdown test will tell you if it's valves or rings/cylinder
Fish
Thanks!
Put up some pics. Try to get a few shots with each valve open, try to show their face.
Jeffalex2
I put it back together, cleaned everything up... have a nice spark... fuel came out the air cleaner... I even adjusted and tested the float when I cleaned out the carb.
To be continued...
Thanks all!!!
