mehan
I have a late model 111 with the original 11 hp engine. When the tractor sits for more than a day it can only be started by jumping from my truck as the tractor battery will not turn over the engine for long enough in insure a start (I can crank the engine for at least 10 minutes before the battery gives up). When engine is warm starting is not a problem as after starting the engine runs well. The engine does use a lot of oil both through gasket leaks which I have not been able to locate and through what I suspect is valve guide clearance as it smokes a lot immediately on starting . It seems to lose prime on standing as it seems to try and start but dies after a few seconds. Should I be looking at fuel pump or carburetor as the culprit. Have not seriously tried starting fluid as the air cleaner is really no fun to open except for scheduled maintenance. Do plan on using starting fluid nex time I try starting. Have checked the plug (new) and find more carbon than I like but no evidence of oil)
Tractor number: M111S331876 (1985?)
Engine: 253707 0155.01
