Scrubcadet10 Moderator Staff member Nov 5, 2019 #1 I've seen it on all of the 12 series vertical shafts airbox.
ILENGINE Lawn Royalty Nov 5, 2019 #2 Some of those engines had a throttle connection point above the air filter, and that is the clamp location for the cable.
Scrubcadet10 Moderator Staff member Nov 5, 2019 #3 ILENGINE said: Some of those engines had a throttle connection point above the air filter, and that is the clamp location for the cable. Click to expand... ah, okay. Makes perfect sense. Thanks!
